5.4lit engine leaking coolant on spark plugs left side.
Dec 29, 2007 at 4:26 PM
✓Experienced Mechanic
Hi there,
pressure test cooling system and look for the coolant loss, have the engine clean and dry first, check carefully and you should locate leak, report your findings if you need further assistance to repair.
