You are just going to have to find the leak. If its on the out side of the cylinder, that leaves a small bit of hope. But it could still be a cracked head and the fluid is just coming out there. This is really odd, and I would look to see if there are any coolant hoses running near by. If the heater core hoses run near the plug, then maybe it is leaking from there and running on the plug.
Good luck
SPONSORED LINKS
Sunday, August 20th, 2006 AT 4:47 PM
