Husband bought 1995 Mustang Cobra belt had slipped off coming home
MRS.ALLRED81
  • 1995 FORD MUSTANG
  • 5.0L
  • V8
  • RWD
  • MANUAL
  • 92,000 MILES
Now it seems like the darn thing sounds like a lawn mower not sure if it had anything to do with belt coming off. I thought maybe a spark plug had exited the cylinder any ideas what is making this 550+ hp beauty sound like a sick lawn mower?
Monday, May 2nd, 2016 AT 10:38 AM
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge first auto parts rent it. Then check for a vacuum leak. Finally check intake vacuum if 15" or below at idle then suspect a clogged exhaust system.
Monday, May 2nd, 2016 AT 12:09 PM
MRS.ALLRED81
  • 5 POSTS
It has nothing to do with belt. It is a super charged 450hp. When started sounds like a lifter or something in the valve area ticking on passenger side ticking. And is idling up and down.
Monday, May 2nd, 2016 AT 2:47 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,348 POSTS
When the belt is off does it still make the noise? I'm thinking the supercharger itself may have a problem.
Monday, May 2nd, 2016 AT 3:09 PM
HMAC300
  • 48,601 POSTS
A lot of supercharged motors will idle up and down due to the cam they are running in it plus the addition of the blower throwing more air into it. Did it do this when he bought it? And is the motor stock as far as being a 5.0 or has that been modified as well? Does this have a pop off valve on it? And it may be a lifter making noise.
Monday, May 2nd, 2016 AT 3:28 PM
HMAC300
  • 48,601 POSTS
Oh and if belt is off or loose then that may be the reason due to not getting the air it needs to run right.
Monday, May 2nd, 2016 AT 3:29 PM
MRS.ALLRED81
  • 5 POSTS
It is stock hasnt been bored or stroked but does have new aftermarket parts and Whole top end has been redone new studs rocker arms and nuts. The belt I just replaced was the supertine although I don't believe thats the problem
Monday, May 2nd, 2016 AT 3:44 PM
MRS.ALLRED81
  • 5 POSTS
Took valve cover off got about three valves that are extremely lose
Monday, May 2nd, 2016 AT 3:49 PM
HMAC300
  • 48,601 POSTS
Then if you have specs on it try adjusting them and the ticking may go away if you dont' have specs then call cam manufacturer if you know what cam is in it they will know the specs. Also adjust while engine is COLD and better to leave.001" loose than to tight. They will tighten up as engine warms up. The way you listed your initial question was that the blower belt blew off.
Monday, May 2nd, 2016 AT 4:03 PM
MRS.ALLRED81
  • 5 POSTS
Rockers arms worked loose and one of them is bent like crazy
Monday, May 2nd, 2016 AT 4:06 PM
HMAC300
  • 48,601 POSTS
There is your problem then. Check for bent pushrods on all of them then. You might look into a rocker shaft see if anything is made for it like from jessel or try summit and jegs. Just for pricing.
Monday, May 2nd, 2016 AT 4:45 PM
