1994 Ford Tempo Freeze Plug Coolant Leak Fix
FATPOSSUM
my girlfriend has a 94 ford tempo with the 2.4L 4 cyl auto and about 100K mi.
after findnig a coolant leak coming from under her car, she took it to her mechanic who said that the freeze plugs need replacing. the estimate was too high, so i am trying to do them for her. i have found four plugs, two of them badly corroded but not leaking, and the leak is coming from between the oil and ATF pans. is there a way to get to that fifth plug without removing the whole transaxle? we live in los angeles, where there is no real risk of freezing. can i just clean and JB Weld the leaks?
Jun 20, 2007 at 7:52 AM
SERVICE WRITER
  • 9,123 POSTS
You can always try it, i have seen stranger things work. Worst case scenario is it doesn't hold and blows open, overheating the engine and turning into a real expensive repair. Or pull the tranny back now.
Jun 20, 2007 at 8:03 AM
Suggested Repair
Pull the transaxle back and replace the leaking freeze plug. A JB Weld seal may be tried, but it can fail, blow open, overheat the engine, and turn into a much more expensive repair.
Conversation Summary
The owner of a 1994 Ford Tempo with about 100,000 miles found a coolant leak and was told the freeze plugs needed replacement. Four plugs were located, but the leak was between the oil and ATF pans. They asked whether the fifth plug could be reached without removing the transaxle and whether cleaning and sealing it with JB Weld was acceptable in a mild climate. The expert said a sealant attempt might hold but could fail and overheat the engine, so the alternative is to pull the transmission now.
