Some other possibilities for vehicle that pulls to left or right.
Front Brake Caliper Locked up - Do you smell anything burning. One thing you can do is jack up the vehicle enough to get wheels off ground and spin the wheels if they spin freely and without noise then all should be good with calipers and wheel bearings.
Rear Wheel Cylinder Locked up - do same as front.
Sway Bar broken or damaged. Most likely with the Fishtail and floating description.
Bad Tie Rod ends.
Wednesday, July 7th, 2010 AT 11:15 PM
