1990 Ford E-Series Van shocks
89,000 MILES • V8 • 2WD • AUTOMATIC
BRUCERB
do i need any special tools to change front & rear shocks? and how hard of a job is ? thanks bruce
Oct 8, 2008 at 6:36 AM
RACEFAN966
  • 5,029 POSTS
No special tools needed. On the front there should be a bolt and nut on the bottom and a stud with a nut on the top (you might have to find a way or buy the socket to hold the shaft to you can loosen the nut. As for the rear it is pretty straight forward it should be a bolt and nut on both ends.
Oct 8, 2008 at 12:22 PM
