1994 Ford Crown Victoria Door Hangs
JUST_GRETA
  • 7 POSTS
Hi. I have a '94 Crown Vic w/140300 miles. The driver's side door hangs when open, and I must lift it up to close it. What's the possible reasons, and might it be a simple thing to fix? Thanks.
Oct 7, 2007 at 9:25 AM
FAIRRACING31
  • 150 POSTS
Sounds like your door hinge bushings are bad. You can pick them up at your local auto parts store. Use a punch and hammer to knock them out. Tap the new ones in. Sometimes its easier to remove the door.
Oct 7, 2007 at 10:39 AM
JUST_GRETA
  • 7 POSTS
Thank you! Very much appreciated.
[quote:1488c1ef57="fairracing31"]Sounds like your door hinge bushings are bad. You can pick them up at your local auto parts store. Use a punch and hammer to knock them out. Tap the new ones in. Sometimes its easier to remove the door.[/quote:1488c1ef57]
Oct 7, 2007 at 11:05 AM
Suggested Repair
Replace the worn driver's door hinge bushings, available at an auto parts store. Knock the old bushings out with a punch and hammer, then tap the new ones in. Removing the door can make the job easier.
Conversation Summary
The owner of a 1994 Ford Crown Victoria said the driver's door hangs when open and must be lifted to close. The expert said the door hinge bushings are likely worn and can be replaced with parts from an auto parts store using a punch and hammer, sometimes after removing the door. The owner thanked the expert.
