1989 Ford Crown Victoria Ignition Lock Stuck Fix
RACHAELSCROWN
1989 Crown Vic - 120k miles
Ignition was sticking and getting hard to turn. Now it's completely locked. Cannot turn key at all. Emergency!! I need my car for work. Please help me!
Aug 10, 2007 at 7:12 AM
BOOTDOG
  • 665 POSTS
first thing to do is get another key made. if that doesn't work then the ignition switch will need replacing which should be performed by a mechanic or someone mechanically inclined. try the key first, and good luck. :)
Aug 11, 2007 at 1:20 AM
RACHAELSCROWN
Problem fixed. Entire ignition switch/tumbler needed relacing. Thank you for your advice.
Rachael :-)
Aug 13, 2007 at 3:54 AM
BOOTDOG
  • 665 POSTS
thanks for being here... tell your friends about us!!!!
Aug 13, 2007 at 5:39 PM
Suggested Repair
Try a newly cut or spare key first. If the key still will not turn, replace the ignition switch and tumbler, preferably by a mechanic.
Conversation Summary
The owner of a 1989 Ford Crown Victoria reported a sticking ignition that became completely locked so the key would not turn. The expert advised trying another key first and replacing the ignition switch if that failed. The owner later confirmed the ignition switch and tumbler were replaced and the problem was fixed.
