1985 Ford Crown Victoria Dies or Won't Start Fix
GUITARLUST213
1985 Ford LTD Crown Vic. Injected 2bbl 302 V8. This car has served me well for over a year. Engine cranks and will occasionally fire right up and drive great. Lately it will just die suddenly at speed or in traffic, and either start again or not. Mostly not. Also when turned off to go into a store, get gas, etc, i come out to have it not start again. Sometimes sitting for an hour or so will let it fire right up, but not today. Three hours of off and on attempts, and had to tow her home. So i replaced the ignition coil, but it still wont start. It appears to be getting fuel, cranks strong, starts right up sometimes, and ocassionally even gets me from point A to point B issue free. What would be the cause of this? I've had many cars and have never had symptoms like this. What would cause a vehicle to run fine then either just die or not even re-start or start. Thanks for any help, Steve
Mar 12, 2007 at 7:18 PM
  • 75,988 POSTS
Could be a bad ignition control module or fuel pump-when it refuses to start check for spark -even if its getting gas might be too much flooding it out.
Go for the spark 1st. then follow with a fuel pressure check
Mar 12, 2007 at 10:10 PM
Suggested Repair
When it will not start, check for spark first. A bad ignition control module or fuel pump can cause sudden stalling and no-restart. After confirming spark, check fuel pressure; excess fuel can also flood the engine.
Conversation Summary
The owner of a 1985 Ford LTD Crown Victoria with a fuel-injected 302 says the engine sometimes starts and runs well, then dies suddenly or will not restart after being shut off. Waiting sometimes helps, and replacing the ignition coil did not fix it. Fuel appears present and the engine cranks strongly. The expert advises checking spark first, then fuel pressure, and suspects a bad ignition control module or fuel pump, noting possible flooding.
