2004 Ford Crown Victoria No Start
129,384 MILES • 2.4L • AUTOMATIC • ELECTRIC
LORELLENELSON
Are we driving down the road in my car completely shut off I replaced the fuel pump alternator and starter and a couple of fuses still no start no crank and no communication from the PCM anti-theft light was on now it's not on still no crank no start need help
Nov 1, 2026 at 3:46 PM
KRAKENAUTO
  • 114 POSTS
If it has no communication to the PCM it won't start. Have you checked the system for any codes stored?
Nov 2, 2026 at 7:15 AM
  • 55,851 POSTS
There are no codes because there is no communication, so I would check the fuses that runt he PCM and swap out the PCM power relay, here are the fuses and the PCM power relay location. Please let us know what happens.
Nov 2, 2026 at 3:43 PM
ABDIELCORTEZ
I had a similar headache with mine shutting off and then nothing at all, so I know how frustrating this is. Before replacing anything else I would check the battery cables and the ground connections, as they can look fine on the outside but be corroded underneath. A quick test with a multimeter at the PCM fuse with the key on will tell you if the computer is actually getting power, and that is where I would start.
Nov 22, 2026 at 9:56 PM
  • 55,851 POSTS
Yep, good call, here is a guide to help as well.
https://2carpros.com/articles/everything-goes-dead-when-engine-is-cranked/
Nov 23, 2026 at 5:32 PM
Suggested Repair
Because there is no PCM communication, stored codes cannot be read. Check the fuses that power the PCM and swap the PCM power relay, then retest for communication, crank, and start.
Conversation Summary
A 2004 Ford Crown Victoria shut off while driving and now has no crank, no start, and no PCM communication. The fuel pump, alternator, starter, and some fuses were already replaced, and the anti-theft light that was on is now off. Experts explained that no PCM communication prevents starting and code retrieval, and recommended checking the PCM power fuses and swapping the PCM power relay.
