2004 Ford Crown Victoria
POPA1974
  • 2004 FORD CROWN VICTORIA
  • V8
  • 23,808 MILES
Tried starting the car and the turns but it won't start. Gave it a jump yesterday and it started. Tried to start the car today and it didn't start. Tried a jump, but didn't work this time.
Saturday, March 7th, 2009 AT 1:30 PM
IMPALASS
  • 3,112 POSTS
Hello -
To better assist you do you have just the Crown Victoria, or the LX, or the LX Sport? Also may I have your engine size in liter and the 8th digit of your VIN.
Okay - if I understand you correctly you turn the key on, the engine rotates....... Never fires off now after the jump yesterday?
Please go to Auto Zone (AZ) or O'Reilly's (OR) and use their tool check out program and get the code scanner. Check your codes, if you find something and you don't get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that.
Also, we need to figure out if it is electrical or fuel related. Pull a plug wire off of the spark plug and insert something into the end of it and have someone try to start the car and have the metal object really close to a piece of metal on the engine and see if you are getting a good strong popping blue spark. Don't have your hands on any part of the metal! If there is no spark, then it is electrical.
If you are getting good spark then spray some starting fluid in the throttle body and try to start it and see if it tries to start then.
You may need to get a fuel pressure check on the fuel pump to ensure it is putting out okay. We will see.
Saturday, March 7th, 2009 AT 6:00 PM
