1993 Ford Crown Victoria wont start
SLOAN TURNER
  • 1993 FORD CROWN VICTORIA
  • V8
  • 100,000 MILES
1993 crown it would die sometimes now it trys to start but wont
Friday, June 13th, 2008 AT 2:45 PM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
Friday, June 13th, 2008 AT 3:00 PM
Related Engine Not Running Content
How to fix an engine that wont start
VIDEO
