1993 Ford Crown Victoria Will Not start
TRACKLIFE
  • 1993 FORD CROWN VICTORIA
  • V8
  • 100,000 MILES
I left my car key turned foward for about 45 mins the other day. I though it was the battery also. Got a jump it still wouldn't turn over. I already went an got a new battery, checked my fuses, wires on the starter and alternator. Checked my button in the trunk that resets my fuel pump. Changed out my ignition switch. Still nothing. Anyone can help me?
Wednesday, October 20th, 2010 AT 3:23 PM
Got a jump it still wouldn't turn over. If its cranking over and refuses to start-do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Wednesday, October 20th, 2010 AT 3:29 PM
