1999 Ford Contour water light
273,000 MILES • 6 CYL • FWD • AUTOMATIC
LISAKERSTEN
the water light on my dashboard comes on when I start the car . Sometimes it goes off right away and sometimes it stays on. I've checked the water level and it's fine. doesn't seem to be leaking any where, and the heat is working fine. On colder mornings , the l;ight will stay on longer. Also if the car is pointed down hill , the light doesn't come on. Could there be a water pump problem?
When the light stays on , I have to drive about a mile and the light will go out.
Oct 6, 2010 at 7:53 AM
WRENCHTECH
  • 20,760 POSTS
There isn't anything called a "water light".
Do you mean the low coolant light? Have you actually removed the filler cap and looked inside. Stains on the inside of the tank can be deceiving.
Oct 6, 2010 at 8:11 AM
