The front driver side running light on my 95 contour does not work. I had the bulb replaced, and the turn indicator works fine, but the running light will still not come on. Is this a fuse? If so where is the fuse located - seems to be two fuse boxes, one under the hood and one under the dash. The box under the hood had no bad fuses. The one under the dash had, according to the guy who looked at, several wires going in and out and he was afraid to mess with it. Ideas?
May 14, 2010 at 11:02 AM
