1996 Ford Contour alternator
1996 FORD CONTOUR
TESSLYNN
Engine Mechanical problem
1996 Ford Contour 4 cyl Front Wheel Drive Automatic
is the alternator the only thing responsible for charging the battery or is there a relay switch or fuse that could contribute?
Dec 24, 2008 at 10:04 AM
  • 110,240 POSTS
The alt is the only thing that produces the current to charge the battery, but the voltage regulator determines how much power the alt is allowed to create. What is the problem?
Jan 2, 2009 at 2:44 AM
