I have followed directions to remove the Alternator from my 98 Ford Contour and have gotten to the final steps of removing the bolts from the alternator. I have taken 2 bolts out that are the lower bolts (located right above my oil filter). I also located 2 bolts that I thought were the upper bolts, I removed one fully and the other is partially stuck due to the frame being in the way I cant pull it all the way out. Still at this point I would think I could move the alternator a bit, but it still feels as solid as if I hadnt taken any bolts out. Am I taking the correct bolts out of the alternator to remove it? Here is a picture I took showing the bolts that I think are the "Upper Bolts". Although the directions show only 1 bolt, which throws me off. Am I trying to remove the wrong ones, what am I missing?
[img:cafb45702e]http://www.2carpros.com/forum/automotive_pictures/137547_altern_1.jpg[/img:cafb45702e]
May 16, 2009 at 5:40 AM
