1993 Ford Bronco Hard Start After Sitting
JMORITZ
I am having problems with my 1993 Ford bronco/5.8 auto with 117,000 miles on it starting after sitting for 6-8 hours. The symptoms consist of with koeo fuel pump runs for a couple of minutes to build pressure then truck will start and run good all day unless truck sits for a while. I have changed the in-tank fuel pump,fuel pressure regulator x2 ,fuel filter,02 sensor,throttle position sensor, temperature sensor, MAP sensor,air sensor and a complete tune-up. I also did a diagnostic with hand held and also jumper wire to check for codes. The code 111 came up for all good. Did check fuel pressure on fuel rail and it was good at koer. I also checked the resistance on injectors and that was good. I also did check vac on intake. Thinking leaking injectors? Help! Thanks.
Feb 23, 2007 at 3:41 AM
Good evening,
I would check the actual fuel pressure with the engine running, Then let it sit with the gauge attached and see if the pressure drops to 0.
If it does, then it is either the fuel pump check valve or yes, a bad injector leaking down.
Mar 25, 2020 at 9:11 AM
Suggested Repair
With a gauge attached, check fuel pressure while the engine is running, then let the vehicle sit and see if pressure drops to zero. A drop points to a failed fuel pump check valve or a leaking injector.
Conversation Summary
The owner of a 1993 Ford Bronco 5.8 reports hard starting after sitting 6-8 hours, though it runs well once started. Many fuel and sensor parts were replaced, code 111 indicated no faults, and running fuel pressure was normal. The expert recommends a residual pressure test; if pressure falls to zero, the cause is the fuel pump check valve or a leaking injector.
