Fan Clutch
CHILIENOJADO
1993 Full Size Bronco. 5.8 Litre (351 ci) w/ac.
I have a constant chirp at start up.
A full squeel after running for about 1/2 hr.
I used a stethiscope on all the pullys except the fan clutch.
Everything is running smooth.
I removed the fan and fan clutch.
The spindle turns real hard but after a minute of turning it the spindle turns (almost) freely.
Shoud the spindle turn real hard at first and then loosen up?
Or should the spindle turn freely and then begin to turn harder.
As the motor begins to warm up, then become hot, it seems to me the clutch should engage more and more until it is fully engaged turning the fan at max.
Think I need a new fan clutch?
Regards...Ron L
Feb 16, 2006 at 9:02 AM
LOVESCARS
  • 359 POSTS
The clutch should engage the hotter the engine gets. This is a commonly overlooked item that can cause other problems that chirping.
Check the water pump?
Feb 16, 2006 at 12:45 PM
Discussion summary
Fan Clutch
The driver has a 1993 Full Size Bronco 5.8L with a constant chirp at startup and a loud squeal after about 30 minutes. They used a stethoscope on all pulleys except the fan clutch, found everything else running smoothly, then removed the fan and clutch; the fan spindle initially turns very hard but after about a minute of turning becomes almost free. The driver expects the clutch to engage more as the engine warms and asks if the fan clutch needs replacement.
Reported outcome: No resolution reported by the poster; they described observations and asked whether the fan clutch needs replacement.
Read the original discussion
