1978 Ford Bronco No-Start Grinding
78 BRONCO
i have an old 1978 ford bronco. i have been having problems lately with it starting.I have replaced the battery several times and within the last month or two i have replaced the solenoid, starter, and voltage regulator. I still cant get it to start. ALl it does is make a small grinding sound. I tried jumping from the battery to the starter ground post and it started to turn but wouldnt completely turn over. I tthen had the starter tested and it passed.so i kinda think maybe i have the solenoid wired incorrectly but i am not sure can you help with this wiring diagram?
78000 mile on a 400 engine
Jul 2, 2007 at 6:25 AM
MERLIN2021
  • 17,250 POSTS
On the solinoid you should have 3 different sized terminals. The harness has 3 different sized wires, unless it's been modified, you can only hook it up one way! put a wrench on the crank and see if you can turn it!
Jul 3, 2007 at 10:07 AM
Suggested Repair
Match the solenoid wires to the three different-sized terminals; unless the harness was modified, they only fit one way. Also put a wrench on the crank and confirm the engine turns freely.
Conversation Summary
The owner of a 1978 Ford Bronco with a 400 engine cannot get it to start after replacing the battery, solenoid, starter, and voltage regulator. It only makes a small grinding sound. Jumping the battery to the starter ground post made it begin to turn but not fully crank, and the starter tested good. The owner suspects incorrect solenoid wiring. The expert says the solenoid terminals and harness wires are different sizes and can only connect one way unless modified, and recommends trying to turn the crank with a wrench.
