I put a accel perfomace coil on and now my idle speed is 1500 rpms whats wrong
Mar 31, 2006 at 5:38 AM
Drive about 50 miles so the computer can reset to the new coil. Idle is controlled by the idle air solenoid, a round silver part on top of the intake. Remove it, clean out the carbon, and reinstall it after those miles.
A 1996 Ford Bronco idles at about 1500 rpm after an Accel performance coil was installed. The expert said the computer needs about 50 miles of driving to reset to the new coil, and that idle is controlled by the idle air solenoid on top of the intake, which should be removed, cleaned of carbon, and reinstalled after those miles.
