1988 Ford Bronco Surging Idle
RGSPIKER66
I have an 88 bronco xlt w/5.8l, the motor seems to idle at around a 1000 rpm's then it will settle down to normal, and idle back up again. It does this just about all day. Thanks for any and all help. Ray
Nov 30, 2006 at 11:56 AM
CATCH_15
  • 250 POSTS
Check for any leaks in the intake, etc.
Dec 1, 2006 at 3:46 AM
1BIGG1
  • 61 POSTS
might want to check your idle ait control valve as well.
Dec 3, 2006 at 12:21 PM
Suggested Repair
Inspect the intake for vacuum or air leaks, and check the idle air control valve.
Conversation Summary
The owner of a 1988 Ford Bronco with a 5.8L engine reports that idle rises to about 1000 rpm, settles to normal, then rises again throughout the day. Replies suggest checking for intake leaks and inspecting the idle air control valve.
