Ford Bronco hard to start
KEVIN BADGLEY
  • FORD BRONCO
Engine problem
Ford Bronco V8 Four Wheel Drive Manual 140000 miles
I have a 1976 bronco with a 302. It is hard to start. When warm. When it sits overnight, I get in, pump the gas 2 or 3 times, and it usually starts right up. However, sometimes when I am driving, it dies, like someone flipped a switch, and then it doesn't want to start. This morning I drove for 10 - 15 minutes with no problem, shut is off, came back out 30 minutes later and it wouldn't start. It took me 30 minutes of turning it over for 3 to 5 seconds, then letting it rest, then trying again. After I got it started, I drove for 5 minutes and it died, but then it started right up. I shut it off, went in the store for 15 minutes, when I came out it started, I drove for 1 or 2 minutes and it died again, then it took me 20 minutes to get it going. Then it made it all the way home, 10 Minutes (5 miles) without stopping. One thing I notice when the bronco is hard to start, it seems like the car doesn't even try to start until I am releasing the ignition. In other words, I turn the key to start the car, it turns the engine over but doesn't "really" try to start until I am releasing the ignition, just before the engine stops turning over, it tries to kick. Help!
Tuesday, February 5th, 2008 AT 3:39 PM
Is this an EFI or Feedback Carb?
Lets check the fuel pressure to rule out the fuel pump and comeback with the pressure readings. Before we move to a different area.
Tuesday, February 5th, 2008 AT 4:25 PM
KEVIN BADGLEY
No EFI, this engine has a carb. One thing I tried was spraying starter fluid into the carb when I was having trouble starting it. Thinking, if it was a fuel problem (vapor lock) then this would at least allow the car to start briefly, then probably die. This did not help, it seemed to make it a little less willing to start.
Tuesday, February 5th, 2008 AT 4:37 PM
KEVIN BADGLEY
How do I check fuel pressure? Do I need to buy a guage?
Tuesday, February 5th, 2008 AT 4:46 PM
Lets try checking for spark-disconnect a sparkplug wire or two and ground it to the engine and have helper crank engine over-Do you have a snapping blue spark? If it looks orange color the coil is weak.
Tuesday, February 5th, 2008 AT 10:40 PM
KEVIN BADGLEY
I called one of the Bronco Parts Stores and asked one of the guys about this problem. He told me it sounds like the ignition module. So, I replaced the Ignition module and it seems to have fixed the problem.
Thanks for your help.
Friday, February 8th, 2008 AT 11:48 AM
