1996 Ford Bronco Hard to start when it rains or sits a few
1996 FORD BRONCO
192,000 MILES • V8 • 4WD • AUTOMATIC
BILLIBOB2K
Truck is difficult to start when it rains and also when it has sat a while usually a couple of days. Once it has been started and has run for a while it will startup with no problems and continue to operate normally as long as the above mentioned to conditions haven't happened. There is also usually a strong smell of gas after several attempts at turning it over. Haven't tried anything as of yet to fix it although the fuel pump has been changed within the last year. Someone suggested changing the distributor cap. any suggestions would be appreciated.
Aug 2, 2009 at 4:47 AM
BLACKOP555
  • 10,386 POSTS
iff its when its damp out then i would suspect an issue with the ignition system. to check it start vehicle on a warm day and spray around with a salt water mixture when you see electricty arc or vehicle run rough you found the problem.
Aug 12, 2009 at 12:56 PM
