HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Bronco
Fuel System
Fuel Pump
Fuse
SPONSORED LINKS
1996 Ford Bronco fuel pump
CMBRONCO
MEMBER
1996 FORD BRONCO
Engine Performance problem
1996 Ford Bronco V8 Four Wheel Drive Automatic
fuel pump wont kick on. She was running just fine an hour ago. Where can I locate the fuel pump fuse? What else should I try?
Thursday, January 14th, 2010 AT 4:09 PM
MECHANIC
You're looking fuse no.16 20amp in the engine compartment fuse box, left side of engine compartment
SPONSORED LINKS
Thursday, January 14th, 2010 AT 4:55 PM
CMBRONCO
MEMBER
Thanks so much!
Do you know which position the fuel pump relay is?
Thursday, January 14th, 2010 AT 5:41 PM
MECHANIC
No pic available but its in the engine compartment fuse/relay block
Thursday, January 14th, 2010 AT 5:59 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Fuse Content
No Fuel Pressure Or Fuel Injector Pulse
I Just Installed New Engine But Have No Start. There Is No Fuel Pressure Or Fuel Injector Pulse. Checked Fuel Pump Relay And All Fuses And...
Asked by
pchefsonya
2 IMAGES
1988
FORD BRONCO
VIDEO
Fuel Pump Control Module Fuse Replacement
Instructional repair video
1989 Ford Bronco Fuel Pump Relays
I Have Been Able To Get Fuel Pressure To The Engine With The Pumps Using A Bypass On The Fuel Pump Relay But It Will Not Start. When I...
Asked by
marrp
1989
FORD BRONCO
Engine Wont Start I Have Replaced Both Fuel Pumps?
I Have Replaced Both Fuel Pumps But Still Don't Get Gas To The Injectors. I Can Spray Gas In The Throttle Body And It Runs Great As Long...
Asked by
jeffandangie
1 IMAGE
1987
FORD BRONCO
1989 Ford Bronco How To Replace My Fuel Pump
Engine Mechanical Problem 1989 Ford Bronco V8 Four Wheel Drive Automatic Need A Class On Fuel Pump Replacement. Hope You Can Help Me.
Asked by
Taught
1989
FORD BRONCO
Fuel Pump Does Not Work
The Vehicle Turns Over Well, And I Am Getting Spark But The Fuel Pump (new) Does Not Run Unless It Is Grounded Out At The Self Test Plug....
Asked by
ozziesstang
1 ANSWER
1987
FORD BRONCO
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
Engine Not Starting
Online car repair manuals
