When I hooked up a jumper to ground off of the fuel pump test connector on the ecu connector
Which pin out no. 8 or 22 either the coil side of the relay is not getting power or the relay is not being grounded by the computer
SPONSORED LINKS
Tuesday, August 25th, 2009 AT 5:08 PM
