Its like grizzly. If your going to tackle this by yourself, I would recommended borrowing a transmission jack. It wil be a lot easier on yah. The tank drop is not that bad but once you get it lose, watch out not to stretch the wiring harness. And you will need to get a set of gas and ac line tools as these will be used to remove the gas lines. They, re about 13.00. Once out it will have a locking ring that will be rotated CCW. The install is reverse of removal of course. I would change fuel filter while I had it down such as the fuel pump sock. I hope this helps.
Saturday, December 5th, 2009 AT 10:49 AM
