1995 Ford Bronco Problems with losing power
130,000 MILES • V8 • 4WD • AUTOMATIC
ETTESSERB
We were driving our bronco and it started acting funny and the volts meter read low and still is after changing the altenator. When the problem occured the truck lost all lights and electrical then finally stalled. We waited for a few minutes and it started back up and we could drive it a little farther. We changed the altenator and cleaned up all the grounds and the volts meter is still really low. Not sure what the problem is.
Oct 23, 2010 at 7:57 AM
  • 75,988 POSTS
Double check wiring/connections if okay check all the fusible links and fuse P 50amp
Oct 23, 2010 at 12:20 PM
ETTESSERB
What do you mean by fusible links? and We are not sure what the P 50 amp is....
Oct 24, 2010 at 8:19 AM
