1989 Ford Bronco lack of power after warmed up
1989 FORD BRONCO
RES94
Engine Performance problem
1989 Ford Bronco 6 cyl Two Wheel Drive Automatic lots miles
My 89 bronco II 2.9L automatic has lack of power after it gets warmed up. After taking off from a stop I have to floor it to gt it moving. It also pings quite often (not due to bad gas) Why is this?
Oct 25, 2009 at 2:22 AM
  • CERTIFIED EXPERT
  • 110,176 POSTS
The valve ping could be cause by the knock sensor. As far as the loss of power, have you checked to make sure the catylatic converter isn't plugged? A plugged converter woll cause both loss of power and a ping.
Let me know what you find.
Nov 15, 2009 at 12:52 AM
