1994 Ford Bronco still loss of power
107,000 MILES • V8 • 4WD • AUTOMATIC
WEEZILLB
  • 9 POSTS
my bronco only got about 60% of the power it had when i first got it a year and 8 months ago when it had 85000 miles on it . within the last 6 months i changed the air filter, fuel filter, plugs, wires, distributor, o2 sensor on the exhaust, and a throttle bore service. also when i first got the truck i use to get on average 13.5 mpg and now i get 10.1 mpg and still decreasing. also the truck really lags at half throttle and it will go better at quarter throttle. i was told to put some fuel injector cleaner in and engine restore, but i was also told to watch what i use cause it might cause more problems then what i got. so i am asking for any suggestions at all to regain my power and fuel economy, or what kind of injector cleaner i could use and if engine restore is ok to use?
thanks to all,
Leon
Dec 8, 2008 at 6:25 AM
RENAUDTN
  • 636 POSTS
a good product is seafoam. Make sure you read all the instructions if you use it.
If I were you I would also check the exhaust system:
If it's getting clogged, it can result in the symptoms you're describing (loss of power etc).
Try to clean your MAF sensor as well (with electronic cleaner). It may help.
Dec 9, 2008 at 2:34 AM
WEEZILLB
  • 9 POSTS
how do i check the exhaust system? i know the catylitic converter get clogged but how do i check and what else should i check on the exhaust?
Dec 10, 2008 at 9:02 AM
RENAUDTN
  • 636 POSTS
Hook a pressure gauge to your exhaust system (remove the O2 sensor and plug it there).
Start the car and check your reading; you should have between 0 and 1/1.25 psi at idle.
If you read much higher than that, you have a restriction. Check the pipe, muffler and converter.
Something else you could check: compression
Hope this help
Dec 10, 2008 at 11:00 AM
