1995 Ford Bronco
BRIDGETTELOVING
  • 1995 FORD BRONCO
  • 6 CYL
  • 4WD
  • 102,000 MILES
I took my truck to the river got it stuck in the river had it pulled out. Drove to another spot it was working fine. Left the river and went up a steep hill. Toward the last of th hill the truck running rough. Drove it home. Drove about 10 more miles. Changed Oil and transmission fluid. Now the truck does not go into gear at all. It does turn on but does not enage to any gear. Help?
Saturday, June 26th, 2010 AT 9:38 AM
  • 109,885 POSTS
Is this a Bronco II? Has the check engine light come on? Was there water in the transmission when you changed it?
Tuesday, June 29th, 2010 AT 11:53 PM
BRIDGETTELOVING
No this is not a Bronco II and I don't think it had water in the transmission and yes the check engine light does turn off and on for awhile.
Friday, July 2nd, 2010 AT 11:17 PM
  • 109,885 POSTS
If it doesn't go into gear at all, I would double check your work on the trans service. Make sure the filter is attached properly. If it is, then you may need to have the computer checked for damage. If you had no water in it, something other than the trans is the problem. It wouldn't go out all at once.
Saturday, July 3rd, 2010 AT 12:56 PM
