I have been driving a 93 ford bronco with a 5.8 liter windsor for years but in the past year it has become harder and harder to start when its warm. It starts rather good when cold (does crank over twice during the turn of key before starting) when engine is at operating temperature and is not started right back up, after about 30 min of sittin with motor off it refuses to start. It just cranks with no attempt of starting for entire first crank then it hesitates but will usually start second crank any help would be great! Thanks
SPONSORED LINKS
Monday, November 17th, 2008 AT 12:24 PM
MECHANIC
Hi:
Have you tried a fuel injector cleaner? Also, you may want to have the fuel pressure checked. The fuel pump could be getting tired of loosing its prim.
