1993 Ford Bronco wont start
208,000 MILES • V8 • 4WD • AUTOMATIC
GLOCKMAN
i just put a new starter in it still wont start please help
Jul 8, 2010 at 7:35 AM
  • 75,988 POSTS
What is it doing? cranking over and will not start or just won't crank at all/nothing
Jul 8, 2010 at 7:42 AM
GLOCKMAN
i put new starter in it wants to crank over but it wont it tries to start then just shuts off
Jul 8, 2010 at 8:26 AM
  • 75,988 POSTS
Do below to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard i
Jul 8, 2010 at 10:31 AM
