1991 Ford Bronco engine
RICKYTAN
  • 1991 FORD BRONCO
  • V8
  • 4WD
  • 125,000 MILES
Hi my name ricky. I've recently replace the fuel pump and now the car dose not want to start unless I spray stater fluid into the throttle body
Tuesday, April 27th, 2010 AT 10:59 PM
Check the fuel pressure if it's within specs.
Wednesday, April 28th, 2010 AT 3:27 AM
KEVINJRGASTON
  • 17 POSTS
Check the fuel pressure regulator for vacuum and make sure it is within specs. Also make sure to keep the plugs clean because starting fluid can cause them to foul out
Friday, April 30th, 2010 AT 1:15 PM
