1991 Ford Bronco bronco will not fire up
153,000 MILES • V8 • 4WD • AUTOMATIC
RONALDJUNIOR1983
i have a 91 bronco that will not start. its has always started on the first time. i started it this morning let it idle for 10-15 min got in it put it in drive touched the gas and it stalled. then tried to turn it over and all it did was crank over. i did this enough time till i could hear the battery dying. get back in it 1 hour later and will crank but will not fire....never had this prob its always started
Dec 1, 2008 at 6:29 AM
  • 75,988 POSTS
Try doing below to determine if its fuel or spark problem this is where we start.
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Dec 1, 2008 at 6:34 AM
