1990 bronco fuel pump runs for several minutes then my truck will start will not start till the pump quits it does this when its cold when its hot it starts fine i've changed the fuel filter the pump seems to be fine cause its running i took the line off at the engine and there seems to be plenty of pressure .could this be my regulator ?or a sensor ?or something else any help would be much appreciated
Aug 23, 2008 at 10:51 AM
