Hi there,
It sounds like an internal failure of the transmission, You can only check that it has ample transmission fluid, check that it is not smelling burnt and it is a very dark colour. If you have the know how, remove the transmission pan and check for metal fragments and excessive clutch material in the bottom of the pan.
Mark 9mhpautos)
SPONSORED LINKS
Friday, November 30th, 2007 AT 8:08 PM
