1984 Ford Bronco where is it
STUD22
  • 1984 FORD BRONCO
  • V8
  • 4WD
  • 54,000 MILES
Hey I have a 1984 ford bronco that has 4 wheel drive. When I am driving it, if I honk the horn or put it into reverse or even turn my blinker on it dies. I have taken it to a mechanic and he has been looking for a short for over 3 months and has still not been able to find it. Could u tell me where I should try and look. The mechanic is now putting it back together so I am going to have to try and fix it myself? HELP!
Tuesday, January 6th, 2009 AT 3:29 PM
BILLYMAC
  • 2,204 POSTS
I would replace the ignition switch, not the key and tumbler but the switch under the coloumn. Remove bolts under col. Lower col. You will see a switch. The part is fairly cheap and easy to change and will cause all the symtoms. Billymac
Sunday, January 11th, 2009 AT 10:05 PM
JAMES11
  • 14 POSTS
Where is it at?
Thursday, January 15th, 2009 AT 12:25 PM
BILLYMAC
  • 2,204 POSTS
Remove the lower dash cover where your knees would be. There is 2 or 4 bolts holding the steering coloumn. The coloumn will lay right down on the seat. Switch mounted on top of coloumn
Friday, January 16th, 2009 AT 4:01 PM
JAMES11
  • 14 POSTS
I tried replacing that switch but no solution. Im thinking that it may have something to do with the starter relay red wire
Wednesday, January 21st, 2009 AT 8:17 PM
