1984 Ford Bronco throttle
TODD S
Engine Mechanical problem
1984 Ford Bronco V8 Four Wheel Drive Automatic
How do you adjust the throttle on an 1984 bronco with a 351 w
Jan 1, 2009 at 5:25 AM
  • 110,251 POSTS
Hi:
I believe your vehicle still has a carb on it and is not fuel injected. If I'm wrong let me know.
Where the linkage connects to the carb the connection is to the butterfly at the base of the carb. There will be a base idle screw that is used to move the butterfly assembly to where the idle is near 900RPM's.
Let me know if this helps.
Jan 4, 2009 at 6:05 AM
