HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Bronco
Drivetrain
Transfer Case
SPONSORED LINKS
1990 Ford Bronco
RICHARD ARMSTRONG
MEMBER
1990 FORD BRONCO
Engine Performance problem
1990 Ford Bronco V8 Four Wheel Drive Automatic
I HAVE A 1990 BRONCO WITH A 302 MY PROBLEM IS THAT IT IDELS FINE BUT WHEN RUNNING DOWN THE ROAD IT STARTS RUNNING REALLY ROUGH
Thursday, September 10th, 2009 AT 1:36 PM
MECHANIC
Do you have a check engine light and when was the last tune-up?
Could be a fuel pressure problem or parameter sensors-we start at the fuel pressure record the readings and then get back
SPONSORED LINKS
Thursday, September 10th, 2009 AT 1:57 PM
RICHARD ARMSTRONG
MEMBER
The last tu ne up was a year ago how do I check fuel preasure? No check engin light
Thursday, September 10th, 2009 AT 2:21 PM
MECHANIC
Find the fuel pressure test port -hook-up the fuel pressure gauge and then turn key to run and record the pressure
Thursday, September 10th, 2009 AT 2:56 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1990 Ford Bronco Does Not Moov When I Put It In Gear
Transmission Problem 1990 Ford Bronco V6 Four Wheel Drive Automatic 894521 Miles It Starts But When I Put It In R It Ingages Somtines...
Asked by
williamseaman
1 ANSWER
1990
FORD BRONCO
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1989 Ford Bronco Help
1989 Ford Bronco Four Wheel Drive Automatic I Have A 1989 Ford Bronco 4 Wheel Drive Has Been Taken Care Of Perfectly Since Date It Was...
Asked by
kermitjones
1 ANSWER
1989
FORD BRONCO
1984 Ford Bronco Where Is It
Hey I Have A 1984 Ford Bronco That Has 4 Wheel Drive. When I Am Driving It, If I Honk The Horn Or Put It Into Reverse Or Even Turn My...
Asked by
Stud22
1984
FORD BRONCO
1987 Ford Bronco
1987 Ford Bronco 6 Cyl Four Wheel Drive Automatic Were Is The Fuel Pressure Regulater On A Eddie Bauer Eddition Bronco 2, 2.9 Liter...
Asked by
girllovesphotography
1 ANSWER
1987
FORD BRONCO
1985 Ford Bronco It Wont Go
Transmission Problem 1985 Ford Bronco V8 Four Wheel Drive Automatic I Have A Friend With A 1985 Ford Bronco. Every Time He Puts It In...
Asked by
samuel sanders
1985
FORD BRONCO
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Clutch Not Working
Transmission Service
Online car repair manuals
