1985 Ford Bronco it wont go
SAMUEL SANDERS
  • 1985 FORD BRONCO
Transmission problem
1985 Ford Bronco V8 Four Wheel Drive Automatic
I have a friend with a 1985 ford bronco. Every time he puts it in drive it will not go, but as soon as he locks the hubs and shifts the transfercase into 4wheel drive it will go.
Saturday, October 23rd, 2010 AT 12:26 PM
  • 109,885 POSTS
Either the rear differential is bad, the transfer case is bad, or there is no driveshaft on the rear. Is there any noise? Also, I am assuming this has the 4wd shifter on the floor and not the electric shift. Let me know if that is wrong. Also, check the linkage to the transfercase. It may not be moving to the right position. Thus, the transfer case is in neutral rather than 2hi.
Saturday, October 23rd, 2010 AT 9:47 PM
CEEBEE TAYLOR
Joe is right on the money I have no rear drive shaft and my 90 bronco does the same thing
Tuesday, February 13th, 2018 AT 2:01 AM
