1990 Ford Bronco
IATROGENIC
  • 1990 FORD BRONCO
  • V8
  • 4WD
  • 175,000 MILES
KOEO-84-EGR Vac. Solenoid Circuit Failure
KOER:
22 -MAP out of range, 42-HEGO Indicates System Rich, 35-PFE or EVP Circuit above closed limit, 25-Knock Sensor.
Vacuum at idle reads 5 Hg at vacuum tree on air intake and into MAP, and 14 Hg going into brake booster.
EVP solenoid reads 3V at idle.
Recently replaced Vacuum hoses, ACT, MAP, TPS, FPR, EGR Valve, Front Rotors, Brake lines, Air Bypass Valve, Spark Plugs, Spark Plug Cables. Cleaned (and replaced gaskets)Throttle body, valve covers, rocker arms, valve springs. Also cleaned and rebuilt injectors.
Have not replaced TAD, TAB, or EVR solenoid or HGO. No cat conv. On this Bronco. Have not run WOT since changes, and have run 8 or 9 miles since
MAP change.
No knock sensor on engine, and they are no longer manufactured.
Monday, April 5th, 2010 AT 5:29 PM
RACEFAN966
  • 5,029 POSTS
OK first off yes it does have a knock sensor it is on the back of the manifold screwed into the top of the block, and they are available at your local parts stores. Now I do need to know a few things before taking it further. First off what engine 5.0 or 5.8 they are not the same and what problems are you having? What is the timing set at and have you checked for vacuum leaks around the upper plenum and the lower intake?
Tuesday, April 6th, 2010 AT 9:51 AM
