1994 Ford Bronco ticking after spark plug change
1994 FORD BRONCO
100,600 MILES • V8 • 4WD • AUTOMATIC
HAULIN BRONCO
  • 5 POSTS
i just changed the spark plugs and wires i used bosch platinum 2's and autolite wires and i hear a ticking noise from right side of motor and have no idea what it can be? please give some help also i changed these and fuel filter and air filter and still have no power what else can it be? thanks for all your help
Jun 14, 2008 at 2:55 PM
LEGITIMATE007
  • 5,121 POSTS
I dont think you should be using the bosh plugs, let alone a mismatch. get your autolite (recommended plugs and keep the autolite wires as long as they are the recommended ford v-8 wire. then make sure they are gapped correctly, dont go for that "pre gapped) bull some of these people try to spit at you
Jun 14, 2008 at 3:06 PM
