1989 Ford Bronco Engine will not start
120,589 MILES • V8 • 4WD • AUTOMATIC
NESBROOK
While driving the engine suddenly cut off. It does not have a spark so I changed the coil, new distributor cap and rotor. It cranks ok and I can hear the fuel pump activate when I turn the ignition on. It has plenty of fuel. The engine cut off just as if I had turn the key off. I replaced the engine two years ago and it has 12,380 miles on it.
Dec 4, 2007 at 6:49 AM
MERLIN2021
  • 17,250 POSTS
If it has no spark, change the ignition module.
Dec 4, 2007 at 7:14 AM
