1989 Ford Bronco Bronco not starting
180,000 MILES • V8 • 4WD • AUTOMATIC
MICHAELMCGEE7
Hello, I have a 1989 Ford Bronco. Approx. 2 days ago, I went to start it and when turning the key in the ignition, everything shut down when it reached the point where it starts. No electricity in the car at all, and car won't start. I waiting approx 10 minutes, and it started. Today (after driving maybe 30 miles or so on highway) I turned off the car and attempted to start it 15 minutes later, and it happened again. This time, it seems like its dead for good.
Keep in mind, I do have a somewhat powerful stereo system in the car (but I don't think that would be the problem)
Please let me know what you think, as I need to see what I can do as quickly as possible.
Thank You,
Mike M.
Mar 14, 2009 at 11:00 AM
  • 75,988 POSTS
Get the battery and alternator load tested if okay double check connections make sure there's no corrosion and its properly tightened.
Mar 14, 2009 at 11:09 AM
MICHAELMCGEE7
Is there anything that I am able to do from my home? I currently lack the funds to have it brought to a service center to have things checked.
Mar 14, 2009 at 3:31 PM
  • 75,988 POSTS
Do you have a digital volt/ohm meter?
Mar 14, 2009 at 5:43 PM
