1988 Ford Bronco Keeps Dying!
BRONCO1988
  • 1988 FORD BRONCO
Engine Mechanical problem
1988 Ford Bronco Four Wheel Drive Manual
I was wondering if you would know why my 88 Ford Bronco 2 Keeps dying while i'm on the Road?
Wednesday, June 9th, 2010 AT 7:23 PM
Next time it stalls try to catch it don't wait for nothing do below immediately to determine if its fuel or spark issue.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Wednesday, June 9th, 2010 AT 7:30 PM
