1988 Ford Bronco
J ROCRICKET
  • 1988 FORD BRONCO
Engine Mechanical problem
1988 Ford Bronco 6 cyl Four Wheel Drive Manual
what kind of price do you think it would cost to fix our bronco2 it has a blown head gasket so were gonna switch engines with another bronco2 then ours will also need some plate on top the transmission because our shifter can move all the way horizontal when going from fourth to drive. We are also going to put in a new clutch and clutch plate to be on the safe side! What do you think on an estimate that would cost us?
Wednesday, October 15th, 2008 AT 9:07 PM
BLACKOP555
  • 10,371 POSTS
New engine? Whats the engine cost?
You replacing it yourself, having a shop do it?
Id go to a junkyard and get a engine and trans together for maybe 2,000 bucks, bolt it right on and your good to go other then piecing stuff together.
Wednesday, October 15th, 2008 AT 9:29 PM
