1988 Ford Bronco
J WALKER
  • 1988 FORD BRONCO
  • V8
  • 4WD
  • 55,000 MILES
My 88 Bronco wont start changed the cilinoid checked the starter the headlights and everything else functions as should just wont start
Wednesday, March 17th, 2010 AT 4:33 PM
Pick your symptoms and gets back with some testing results
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch/clutch switch and ignition switch assuming the battery and connections are good
Wednesday, March 17th, 2010 AT 5:07 PM
