Transmission problem
1988 Ford Bronco Four Wheel Drive Manual
do you have to remove the hydrolic line to remove the transmission
Monday, November 30th, 2009 AT 2:27 PM
BIGJIM79
MEMBER
The answer is yes and there is a carter pin hold the line on the top of the transmission. Just reach above the trans on the left side right behind the bellhousing and you should feel the pin head. Just pull straight out.
