1988 Ford Bronco
DLAURIA
  • 1988 FORD BRONCO
  • 4 CYL
  • 157,000 MILES
The transmission fluid level is to full. How do I get it to a normal level? Also there is no drain plug, only the pan.
Saturday, January 12th, 2008 AT 2:20 PM
BLACKOP555
  • 10,371 POSTS
The tranny pan will have to be dropped or if you have a small piece of hose you can siphon it out of the dipstick hole!
Then when you get it down to an estimated good level drive for about 35 miles and then park it leave the engien running and check the fluid again. If its too low add more if its still too high remove soem more.
Tuesday, March 18th, 2008 AT 8:22 PM
